E36 all over the road
Hi all,
I have a 1996 318i and lately it has been a handfull to keep in a straight line.
I removed the tyres and noticed the left front was a little worn on the inside but the rear left was very worn on the inner.
I took it to Beaurepairs to get a wheel allignment and they couldn't figure out what was causing the rear tyre to wear that way.
My wife swears she hasn't hit any gutters.
Any ideas?
thanks
Greg
Old 03-18-2008, 04:25 AM
914 Geek
Sounds like you've got toe-out in front.
--DD
Old 03-18-2008, 07:20 AM
Jeron's Avatar
Alignment or worn suspension
I cant imagine an alignment shop that cant diagnose and repair uneven tire wear.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-18-2008, 07:31 AM
Improper tire pressure?
Old 03-18-2008, 05:53 PM
Thanks for the replies,
Tyre pressure has been fine. The front was out a little but the rear still remains a mystery. They didn't find any worn components, and the rear tyre was down to the wires almost. (on the inner edge)
I spoke with the guy from Beaurepairs today and he told me they had no idea why the rear tyre was out.
They recommend a BMW dealer. Looks like it will be a costly experience...
Old 03-19-2008, 05:30 AM
914 Geek
It still sounds a lot like there is a good bit of toe-out on the rear wheels. That will eat the inner edge of the tire pretty quickly, especially when combined with negative camber (which your car should have, I believe). It will also result in a car that is not very stable going in a straight line.
--DD
Old 03-19-2008, 08:13 AM
stupenal's Avatar
The rear trailing arm bushings may be the culprit. I was experiencing significant rear tire wear, and a floaty rear suspension in turns. Replaced the bushings and now all is fine. If you have over 100k miles on your car, definitely replace them.
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 03-25-2008, 04:42 PM
