Angry PLEASE HELP! Bucking Problem
Hey Guys so I just bought my first e30 two weeks ago and it's a 1988 325is. For the first week the car ran great and then one day began bucking and running real rough. The car will consistently run rough when the engine is cold and will continue to do so until the engine reaches normal operating temperature. At this point the car runs well. It idles well and only bucks while accelerating. I have replaced the fuel filter, coolant temp switch, and sensor. I also cleaned the air intake temperature sensor with a computer/electronics cleaner. I really appreciate any help I can get.
Old 05-21-2008, 07:47 PM
Jeron's Avatar
I'd start simple by checking for vac leaks, intake leaks and check the plug wires.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-22-2008, 09:17 AM
Air intake first, look very close at the rubber elbow and the hoses that connect to it, Also see if your throttle body is clean.
If you don't find it there, your fuel pressure regulator could be bad, or the vac line that controls it, cracked or leaking. The fuel regulator will starve the injectors when you stab the accelerator if it is bad. The engine will stumble.
You can do a quick check by pulling off the vac line at about 2000 rpm. The engine should change rpm, if it is working at all.
I've got an 88 cabro, E30s are my favorite. They are tough as a tractor, if you take reasonable care of them..
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 05-22-2008, 06:03 PM
