psyyambmw's Avatar
Question Identify what DME mod in my e36 I bought, please
I bought 1994 318i since 2002. I found this thing stick in the dme compartment.
double click to enlarge
Does anyone know what da hex is it? What is it for? I am about to replace a new dme, used one. What I should do with it, that dumpmie thing?
More over there is a sign shown this dme had been open. When uncover it, I found some kind of a resister has been replaced here:
What it for? Need some idea about this.
Help Please
FYI: my car is a right-hand steering
Thanks lot in advance
George
Edit 1:
It’s an M42 motor, automatic transmission
Engine just off or rattle on low and idle speed after abrupt stop on high rev once awhile w/o any engine check light on, I just realized that. There is no ‘Check Engine’ light at all. When go to the mech it will be good for awhile and sooner or later it will happened again even replacing w/ a brand new ICV. Recently, I replace the MAF then it gone, run good now.
It doesn’t respond to carsoft
http://forums.bimmerforums.com/forum/showthread.php?t=952429&page=3
my body mod stage I / stage II e36 headlight lens removal
Old 05-10-2008, 06:09 PM
psyyambmw's Avatar
more pic before it pull out
Old 05-11-2008, 05:01 AM
It looks like somone is using this things resistance to fool the DME.
I would check the resistance of it first. Then see if I could locate it's location on the DME plug.
If you figure out it's pin asignments, you can figure out what it is, or was, or needs to be.
Is the cover missing?
If so get one. The DME can get wet even with one in place. you don't have a chance without one.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 05-11-2008, 11:43 PM
your car should have DME M1.7
Old 05-11-2008, 11:48 PM
psyyambmw's Avatar
Thanks for your comment.
The cover ain’t missing though. Let’s forget this DME, I got another one, used, already. I think I’m going to locate the pin of that weird aluminum thing hooked up, next weekend, first. I just was wondering can I just throw it away.
Thanks again
George
Old 05-12-2008, 12:03 AM
psyyambmw's Avatar
Whai is it DME M1.7
Old 05-12-2008, 12:04 AM
Old 05-12-2008, 03:18 AM
psyyambmw's Avatar
Oh! OK! right there in the bentley.
Actually, I just got another one exactly there same part # of that freaky dme.
Old 05-12-2008, 07:26 PM
Jeron's Avatar
If it was OBD-II I would have guessed an O2 sensor bypass.
Can you trace the circuit and figure out which pin it goes to?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-13-2008, 11:13 AM
psyyambmw's Avatar
noop! it's an M42 OBD1.
by the way, there is no reason to bypass the O2. If the O2 broken it just don't send any signal to the dme.
Old 05-13-2008, 08:39 PM
