cat or 02 sensor
Greetings:
I’m get an error code on a ’98 328is, “Catalyst efficiency below threshold Cyl #1-3”. (it's table 11, code E9) Could I get some opinions on whether this means the cat itself is bad or if it could be an O2 sensor issue? Anyone else had to troubleshoot this code? SHould I start with the 02 sensors and hope or go straight for the car? TIA - Dan
Old 05-19-2008, 05:48 AM
Jeron's Avatar
It usually means the cat is bad. Reset see if it comes back then swap the post cat sensors and see if the side changes. Use PBBlaster or the like.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-19-2008, 08:37 AM
thanks Jeron, I'll give it a try
Will give it a shot and report back. thanks...
Old 05-19-2008, 08:50 AM
Cool cat or o2 sensor
Check the intake bellows first, there might be a hole . this intake bellows is between the air flow meter and throttle body, there might be a vacumn leak. I have the same reading, catalyst effeciency below threshold cyl. #1-3, table 11, code E9. good luck, giorgio
Old 05-25-2008, 04:29 PM
On both my '97 328s, the "catalyst below efficiency" code was the first indication of an oxygen sensor that was getting slow to respond. BMW says that they last only 90k miles, and that is about how long the front ones last. I replace all four at once.
I have 400k combined miles on my '97s, so I have replaced several oxygen sensors. You don't need any special tools. A combination wrench works the best.
Old 05-26-2008, 11:02 PM
Tags
02 sensor , cat , code e9
