Please help!
I drove my car to and from work yesterday same as always no problem. then i went to start her today and no dice! all lights come on i even heard a slight click but nothing.
I havent the slightest clue where to begin. the only recent work on her was to change/replace the fuel pump and she purred since.
PLEASE ,PLEASE ,PLEASE, HELP!!
Someone suggested i check the relays, where do i look and which one am i looking at and how do i know if its bad???
THANNKS ALL
Old 10-19-2008, 11:16 AM
The described symptoms can be caused by a number of things. I would start with the battery - how old is it?
Old 10-19-2008, 02:33 PM
this thing seems more like a relay issue than anything..i just need to know which one since ive pulled 'em all out but cant tell for the life of me which one the starter relay or fuel pump relay is.
HELP
Old 10-19-2008, 03:27 PM
I Should update everyone on whats transpired in the last 20mins, so everyone on every forum suggested i check the battery, being a firm believer in taking ppls advise once you ask for it and autozone being just down the road from me i thought i'd high tail it there for a new set of jumpers before they close i also needed to replace the "central door locking" fuse anyways which also blew in the past 24hrs so the trip to me was worth it.
i get there pick up the fuse, come back, plug all the relays i had unplugged back in( i think four in all) then plug in the new/replacement fuse and go to push the car to the end of the garage so i can just nudge the nose of my truck in there and jump her when i realized the steering was locked, so i thought i'd better stick the key in and turned her over for the upteenth time and VOILA!! SHE FRIGGIN ROARED....what the
what do you guys think did it, cos i knew all along my battery/alternator was strong. and having just replaced the fuel pump that was not it.
the fact that i removed all those relays has something to do with it....but which one?
again i still cant identify the starter relay or fuel pump relay.if i did i can isolate and replace them.
Old 10-19-2008, 04:47 PM
Jeron's Avatar
I would have suggested battery as well. You first description is of a classic dead battery.
Based on what happened next it sounds like a sticking relay or the ign switch. Try tapping on the relays next time.
What model/year car?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 10-20-2008, 07:50 AM
it is a 94 325 is with over 200k
Old 10-20-2008, 08:20 AM
