ATF sump thread stripped
I just replaced the ATF on my E36 and found two of the tapped holes on the large sump pan are stripped enough that they can hold the bolt, but not at much torque. The two holes have one good hole between them. All other holes are good too. What do I do?
If they wont hold the bolt you could try teflon tape otherwise a helicoil is you final option.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
