starting issues
Hi there,
'88 325is. I did some mostly tune-up work on a recently acquired e30. It was starting previously, but ran very very rough.
I'm stuck on one problem.
The fuel pump functions fine when I jump it at the relay. However, it does not run when I go to start. The engine cranks and cranks.
Second thing, even when I have a pal to jump the pump, I go to start still with no success.
So I want to determine why the fuel pump is not receiving a signal from the ECU when I go to start.
Once I can figure that out, I'll go from there.
Any ideas?
The relays seems to work and I switched the o2 and pump relay just to double check.
Old 10-17-2009, 06:36 PM
Jeron's Avatar
My guess is the crank shaft position sensor. If the ECU doesnt sense the engine turning it wont fire the pump or the engine.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 10-17-2009, 07:05 PM
