Question Replacing struts
For my 1995 325is, I am ordering the following struts (the one below is only the left side)
VE3-4402-H1-M12
What other parts should I get while I am doing this work?
Should I get the Strut Mount Gasket for Front Strut Guide Support, 31-33-1-094-288-M9?
What about Gasket, for Rear Upper Shock Mount to Body, 33-52-6-772-864-M30?
Old 03-05-2010, 08:38 AM
Make sure you replace your strut mounts, get strut mount gaskets, upper and lower spring pads, and finally new shock boot and shock boot covers.
For all those parts it will be an extra $120 or so, but if you're going to replace the struts you should replace all I mentioned above and well work it because like your struts, you won't need to replace those things until it's time to replace the struts again 35-50,000 miles down the road.
Also, your struts usually come with new nylon nuts, but if they don't, get new ones too. Never use old nylon nuts, especially struts ones that undergo such a beating.
Old 03-05-2010, 02:41 PM
rambog,
That was a loaded question. That was the way I started my strut upgrade, but one thing lead to another and before I knew it, I replaced ball joints, all bushings, strut bearings, links, rack boots; essentially the complete suspension system.
Old 03-10-2010, 04:25 AM
Originally Posted by Yurick View Post
rambog,
In addition to his statement, I did the same. I replaced my shocks/struts with high quality parts and noticed very little change in my suspension. Replacing the the control arms and other front suspension components made 10x the difference.
Old 03-10-2010, 05:54 AM
