Send a message via AIM to Bear
Replacing RearShock
I have a Bentley and Haynes and have read the site how to and still I am confused. Kids 1990 325ic had a rear shock piston rod snap and I am going in and replace the injured shcick. All indications are that I must remove the two (left and right) support bolts in order to remove the shock remains. I thought just taking off the piston rod nut (the one that threads on would release the shock. Give me more information, please.
Old 03-18-2010, 03:40 PM
Hello Sir,
I'm not sure what you're asking, but rear shock replacement is a snap. Each shock has two nuts per shock mount, and a long bolt that connects to the bottom. If possible, use after market shock mount supports, or racing ones. The OEM sucks.
Old 03-18-2010, 07:33 PM
Also use the reinforcing plates..
They go on the top outside of the shock mount. Prevent future sheet metal damage.
Old 03-19-2010, 05:51 AM
Rea Shock Replaement
Job is done and once I had the support bracket nuts off and stuff fell in my face I was almost home. The shock rod had fractured at base of upper support bracket so a bit of the tube and the threaded rod were still attached to bracket. I put what was left in a vise and was able to turn center nut, off thereby saving top piece of the bracket. All went great until I went to put the center nut on and of course the shock tube started rotating. I Had daughter turn the nut down while I lay under and held the shock tube to keep it from rotating, Again, thanks to all who responded.
Old 03-19-2010, 10:59 AM
