Guest
Posts: n/a
I received the error code "C8 - DME control unit selftest" on my 94 318ic. I cleared the code with my Peake scan tool and the CIL has not come back on. What was the error? I have been checking all over without any solution.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Reading BMW Fuel Injection Fault Codes |
Author of "101 Projects"
I'm not sure - I haven't seen this before either. I'm thinking that either this was triggered by a power failure on the bus (dead battery), or the DME had some internal problem and ran a self-diagnostic check on itself.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne. The CIE was triggered after the car sat for 2 1/2 months, winters don't agree with convertibles. I always have a original BMW trickle charger hooked up so a dead battery is not the issue. After starting the car, it ran rough for 10-15 seconds but since then it has run fine. If my DME turns out to be bad, it doesn't look to hard to get to it but if I replace it with a used one, will I need any reprogramming or will any used one (matching part number) work for a 94 318 work?
