Guest
Posts: n/a
88' 325ix. Starts fine, idles fine. Starts to run rough and stumble at 2500 through 3500. At 3500 stops misfiring and runs great. Does it under load and in the drive way.
I have: Adjusted the valves Cleaned fuel injectors + new seals replaced all hoses and double checked em all New valve cover gasket New Fuel Pressure regulator New used o2 senor plugs Crank position sensor exhaust seals and new exhaust Running better of course but none of that made any difference in the stumbling. Any thoughts are very much appreciated Amazing of guys to offer this kind of help! __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW E30 3 Series Idle Speed Troubleshooting |
Author of "101 Projects"
You've already replaced just about everything! I would revert back to old school here, and actually check the timing of the engine with a timing lamp. Sounds like it may have something to do with the mechanicals of the engine, rather than the injection or the ignition (since it runs fine everywhere else). Also run a compression check while you're at it, just to verify the condition of the underlying engine. But, I would suspect something is up with the timing at that rpm range.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
