Guest
Posts: n/a
I have a 92 325is e36 and i drove it the other day and it almost sounds like a Harley. I replaced fuel pump and battery. When the car is cold it starts up ok, but when car is warm it wont hardly start at all unless it cools down, and when I am at a stop light it will idle between 700 to a 1000. when you first press the gas it sputters until it hits 2k then the car is great. i have no check engine light on at all? should i still run the stomp test?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW E30 3 Series Idle Speed Troubleshooting |
Author of "101 Projects"
Yes, your car will tell you what is wrong with it if a sensor is not giving out the proper signals. Take a look at my article on reading fuel injection fault codes in the tech articles section, and that should give you a good clue where to start.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
