E36 DME Question
I am having DME issues and have a 1994 318I with the 261-203-357 DME, can I switch it with a 261-203-282 DME? if I find another 261-203-357 DME will I need to switch my computer chip, or can I plug it in and expect it to run?
PS: I would appreciate a response from anyone what can answer the question asap!!!! Thanks
Old 10-24-2011, 03:05 PM
DME e36 July 1994 318i Bosch OBD I / DME
Were you able to work out an answer to your chip question?
I have a 318i e36 July 1994 Bosch OBD I / DME that does not activate when procedure is followed.
Car is running fine but cannot activate the DME to see the fault codes and apparently it might not be working.
I had no replies to my post either so I was guessing to try replacing the 'chip' without having a clue what I am doing.
Any ideas...anyone?
Cheers
Old 01-26-2012, 03:35 AM
