Possible DME issues
My car is having an issue with hot climate. When in hot climate, it goes to limp mode (RPM quits, temp gauge max, ac shuts off etc). When cools down (5 min with hood open), it works fine. Please see the images for DIS. It was taken after it started working again and so it says not present now. Is this a DME issue? DIS also says (in screenshot), about DME relay issue. Its got CAN bus issues with brake light switch, EGS, Cluster and all. Also please see the last 2 images of DME PCB. Looks fine?
Old 07-20-2012, 12:40 PM
S ECU Repair's Avatar
Can you repost your images?
I can't help you much since I can't see them for some reason.
Specialized ECU Repair
Porsche Bosch Motronic DME Specialists
Free DME Testing for Pelican Parts Members
www.ECUdoctors.com
1-800-328-1425
Old 07-31-2012, 09:25 AM
