E36 Strut Spring Guide/ Plate missing?
Hey Guys,
This is the first time for me working on struts and I think I may be missing some parts. Maybe they fell out. :-D Is the Strut Spring plate or Spring guide visible from outside looking at the spring? I've got a 92 E36 325is (01/92) and the spring actually moves back and forth when you turn the wheel. makes a terrible noise like it's hitting metal on metal. I'm not sure what I'm missing the pad looks like its crushed, Can you guys tell me what I should be able to see from looking outside? I have not yet took it apart as I wanted to order everything I needed before doing so. I was also planning on getting new struts or possibly coil overs and not hurt the budget. ![]() The picture below shows the pad is crushed, but it seems like there should have a plate to hold the spring? ![]() is the plate bottom lip #1 visible from outside looking at the spring? ( I think i see part of it from the top when opening hood) from this diagram it looks like the spring connects to the upper pad #8, and then the plate lip #1? is this correct? ![]() I appreciate any feedback/suggestions! Thanks guys!! Last edited by rdbrock; 04-11-2013 at 07:16 PM.. |
Anyone please?
| Tags |
| coilover , spring plate , strut , struts , suspension |
