LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
I just replaced my clutch flyweel, and all my tranmission bushings and washers using your diy. I put the car back together, and my asc light is on, and I have a code for the crankshaft postition sensor. COuld this be becuse I was turning the dirveshaft to get to the bolts? DId I damage the engine any or will the sensor fix the issue? THanks. I have not tried to bleed the system, and I thnk that may be the problem with the asc.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Camshaft Position Sensor Replacement |
You may have damaged the electrical connector or sensor. Inspect them both. Turning the driveshaft by hand would not damage anything.
- Nick |
Thread Tools | |
Rate This Thread | |
