von (guest)
Guest
Posts: n/a
how do you removed it if it's ceased on there? I can't get mine off.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your 3-Series E30 Oxygen (Lambda) Sensor
Old 05-28-2013, 11:16 AM
Nick at Pelican Parts's Avatar
If you are replacing them use penetration oil for a few hours. If you know how to use a plumbers torch you can heat the O2 sensor bung (the threaded part welded to the exhaust that the O2 sensor threads into) and they try removing it but please use protective clothing and safety goggles.
- Nick
