E30949 (guest)
Guest
Posts: n/a
Diff is droping far enough. Its on jack stands an factory placement. only able to drop the diff 1in mabey 2. Any help
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your 3-Series E30 Rear Springs and Shocks
Old 05-28-2013, 11:21 AM
Nick at Pelican Parts's Avatar
You can slowly loosen the sub-frame mounts. This should get you another inch or two but under no circumstances remove the sub-frame mounting bolts entirely. It will be very difficult to re-install
- Nick
