Guest
Posts: n/a
Diff is droping far enough. Its on jack stands an factory placement. only able to drop the diff 1in mabey 2. Any help
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your 3-Series E30 Rear Springs and Shocks |
You can slowly loosen the sub-frame mounts. This should get you another inch or two but under no circumstances remove the sub-frame mounting bolts entirely. It will be very difficult to re-install
- Nick |
