woodki1 (guest)
Guest
Posts: n/a
I have a 2006 325 BMW that will not run and has no power. Also barely cranks. Hooked up to computer and no fault codes will display. driven car and hooked up to computer still no fault code and still runs horrible. any advice?
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-19-2013, 06:03 AM
Nick at Pelican Parts's Avatar
Be sure the scan tool you are using is advanced enough to read all systems. There could be fault codes stored that you cannot access.
If engine runs bad and no fault codes are stored, check fuel control and fuel trim. Confirm engine has good spark, fuel and compression.
- Nick
