LinkBack | Thread Tools |
Guest
Posts: n/a
any tips on getting the window back into the guides? my passenger window has popped out and broke the slider... luckily had a spare slider from my driver side fix, but when i put it in, it pops out again. Worked out that the window was not in the guide in the front side as well as the back. Can get the back in no problems, any tips for getting in the front of the window into the guide? this is driving me nuts tried for 2 hours :
PS your guide for replacing the window regulator is great. used it to change my drivers side and worked a treat. Thanks __________________ This post was auto-generated based upon a question asked on our tech article page here: |
I would remove the glass from the door, then reinstall it into the guides. It could be stuck on the side of the guide, not allowing it slide easily. Also, check that the regulator is not damaged.
- Nick |
