Xavier (guest)
Guest
Posts: n/a
For my 94 325is, both front turn signal lights are not working while the sides and rear are working same situation regardless if my headlights are on or off, I tried replacing both light bulbs, then bulb sockets but no luck. When I use my turn signals, the turn signal lights in my dashboard flashes very fast compared to when the lights were working properly.
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-03-2013, 05:58 AM
Nick at Pelican Parts's Avatar
The fast flashing indicates a bulb is out. If the front bulbs are not working, I would start there. Check to see if the bulbs are getting power and ground then you activate the turn signal. You may have a broken wire or bad bulb socket.
- Nick
