John (guest)
Guest
Posts: n/a
Hello, I have a 94 325is. The bleed screw figure 13 seems like its not "seating" properly after bleeding the coolant. There is still a slight leak from the area once it is tightened. The expansion tank is new and the bleed screw came with the tank. Any suggestions? Thank you!
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-03-2013, 06:32 AM
Nick at Pelican Parts's Avatar
Check that the rubber gasket is in place. If not, the reservoir may need replacing.
- Nick
