LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
Hi. I need to replace the throttle position sensor on my BMW E36 320i M50 non vanos DME 3.1 Whats the difficulty rating and procedure for a DIY job? I already have the replacement sensor
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The TPS is bolted directly to the throttle bore. You may have to remove the whole throttle bore to make it easier and if you do you should replace the gasket.
- Nick |
