tom (guest)
Guest
Posts: n/a
Thank you for posting this detailed DIY. Would you happen to know any tricks for removing a stripped engine cover nut/post? I can't remove left engine cover, which blocks access to spark plugs...
Thanks for any ideas/light you can shed.
Tom B
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-15-2013, 06:58 AM
Nick at Pelican Parts's Avatar
There is a tool you can buy called an impact driver. Cut a slot with a hacksaw and use the straight bit on your impact driver. then hammer on the driver and it should loosen the bolt
- Nick
