saj (guest)
Guest
Posts: n/a
Hi i have a Bmw E36 318I R reg, reacently the car has been feeling like the fuel is runing out, every now and the the revs have been shooting up and hold there for about 30 seconds and comes back down, the car stall and diffulty starting back up, i have changed the idle air valve and a hose that had split but still no joy, i'm thinking about changing the maf soon, can any one help, thank you in advance.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-30-2013, 05:16 AM
Nick at Pelican Parts's Avatar
I would start by checking the DME for fault codes. If the system is not working properly, a fault code will be set.
You could have a vacuum leak or a faulty crankcase breather valve. I would check both, inspect the engine for a cracked intake boot, vacuum line or leaking gasket. You can also check the crankcase vacuum, this will help you diagnose the crankcase breather valve.
- Nick
