Ershad (guest)
Guest
Posts: n/a
Hi, I have a 2008 bmw320i. The stop when safe and service immediately check light came on, and the car refuses to accelerate above 2500rpm. What could be the problem?
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-22-2013, 04:51 AM
Nick at Pelican Parts's Avatar
I would start by checking the DME for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing. There can be many faults that set this message. I would guess it could be a misfire or transmission issue.
- Nick
