Shane (guest)
Guest
Posts: n/a
If the crank sensor is damaged, will it not allow the the automatic transmission to shift gears? E30 325i. Please help
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-21-2013, 09:35 PM
No the crank sensor is for the DME not the EGS. This is probably a mechanical auto trans. Check your fluid level in your trans.
- Kerry
