Guest
Posts: n/a
Adding to the previous post:
Error code says: Ratio monitoring gear shift 2-3? What does this mean? __________________ This post was auto-generated based upon a question asked on our tech article page here: |
The EGS control unit looks at the input shaft speed sensor and the output shaft speed sensor to tell if the transmission clutches are slipping. This means the 2-3 clutch is slipping. This could be due to a sticking shift/pressure control solenoid or sticking piston is valve body. A fluid exhange may cure this.
- Kerry |
