Conrad (guest)
Guest
Posts: n/a
1999 BMW 528IT, s/n WBADP633XXBV61744.
Each exhaust manifold half has 1 Oxygens sensor. Are the oxygen sensor the same part number? Or are the wirs a different length.
Also is it recommended to replace the exhaust sensors after the catalytic converters or is this replacement unnecessary.
Please advise.
Thank you Conrad Bock.
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-07-2014, 07:44 PM
Nick at Pelican Parts's Avatar
The front sensors are the same part number. The rear sensors, although different from the front, share a part number with each other. If replacing two, you might as well replace all four.
- Nick
