markovnik222 (guest)
Guest
Posts: n/a
hi. i have a problem with my MAF sensor. when MAF sensor is connected i start a car he's cut off. when i disconnect a plug from MAF sensor car starts good. i had changed to a new MAF sensor, still the same. i tried to blow into MAF sensor when he's connected engine starts cut off. i think maybe when i replaced a new MAF sensor i need reset ecu. any ideas what i need tyo do? thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-20-2014, 06:49 AM
Nick at Pelican Parts's Avatar
Have you checked for fault codes? I would assume the MAF is not your issue. You may have a vacuum leak or fuel delivery issue.
- Nick
