1995 325i (guest)
Guest
Posts: n/a
I've got a 1995 325i. I have a dead miss on cylinder 1, it does not fire. compression is good, spark plug, coil, and wires are good. I suspect a dead injector? the plug is dry when pulled. here's the weird part, when I pulled the codes from the DME, it gave me the code 1256 for injector #6. But cylinder 1 is where the problem is. I was thinking of just getting a reman set of OEM injectors. Thoughts? Thanks.
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-20-2014, 07:27 AM
Nick at Pelican Parts's Avatar
Easier thing to do is swap an injector from another cylinder to the bad one. If the problem follows the injector, replace it.
- Nick
