Carmen (guest)
Guest
Posts: n/a
I have replaced all lamps, rear light assemblies and brakelight switch. I cannot get my driver side running light to work along with my driver side tail light and brake light. I know the rear assembly on the driver's side is good as it works if I plug into the passenger side rear wiring system. So it must be the driver side wiring system? Can you make any next step recommendations?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Troubleshooting Electrical Problems on Your BMW
Old 11-18-2015, 09:48 AM
Nick at Pelican Parts's Avatar
What vehicle are you working on? You can start by getting a wiring diagram. COnfirm the correct signal is getting to the splice or junction for that light.
- Nick
