Question Changing rotors
Since the tech article isn't posted yet, I'll throw it out to the group. I need to change the rotors on my 91 318is. Lookinig at the Haynes manual, it doesn't look like a bad job. Am I kidding myself? Any tips?
Old 12-23-2002, 05:43 AM
From what I can tell, its pretty straightforward.
Say, can you drop me an email sometime? Im seriously considering a 318is and would like to ask a few questions.
much appreciated
Jeff at WallWerks
wallwerks@cox.net
Old 12-23-2002, 07:28 AM
BMW Roundel rotors
Brake pads and rotor replacements are a good first project. All you need is a little mechanical ability. Make sure you replaced the allen screws that hold your rotors to the hub with new ones and use a little antiseize grease on them. Also be prepare for the one that won't come off easy and you end up stripping the head. if that happens don't worry go to Napa and get there screw extractor pack (10.00).drill the biggest hole you can inside the thread diameter and then turn the extractor you'll have it out in no time.
Old 12-26-2002, 04:01 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Exactly what mcanales said, changing rotors is very easy. You'll have to remove the calipers before you remove the small allen screws, however.
Old 12-26-2002, 05:48 PM
wayne:
Yes, I may be inheriting another e30. My buddy at the detail shop owes me for some art and may give me a 318i as payment.
This might be a good big motor (b50 from a newer vintage e36) swap project. What do you think?
Old 12-27-2002, 01:07 AM
Jeff, im going to have the tech article done by Monday. Keep looking.
Old 12-27-2002, 09:14 AM
