problem installing my guide arms on 335-e92
So I basically have the TRW versions of each of the parts below.
When two different indy shops tried to put them on the 07 e92 they could never get them to align up.
I am considering trying the effort on the 13IS.. any idea why this might not work successfully?
https://www.getbmwparts.com/partlocator/index.cfm?action=MorePartInfo&PartID=781441&siteid=214672&catalogid=4462
https://www.getbmwparts.com/partlocator/index.cfm?action=MorePartInfo&PartID=781430&siteid=214672&catalogid=4462
Old 04-29-2017, 11:28 AM
Administrator
Dmitry at Pelican Parts's Avatar
You mention in the header that you have a 335, but the links are for parts for an M3.
Old 05-01-2017, 10:15 AM
But the links state they can be retrofitted.. so do they bolt in or not?
As the third member is the same, (on early 335s which have big center at a min), they should bolton correct?
Old 05-01-2017, 03:06 PM
Administrator
I cannot confirm this - it says "at your own risk" which likely means that you'll be doing some sort of fab. work - I'm guessing that they do not bolt on without modification.
Old 05-02-2017, 03:16 PM
Yeah, just about all the M* parts say that.. Even front tension arms
Old 05-03-2017, 07:20 PM
I have since talked to another e92 owner who has made this swap with no issues on 5 other vehicles using exactly the parts identified above.
Old 05-23-2017, 01:09 PM
