What part is this
Can some one tell me exactly what part this is"Picture of Part" I thought it was the idle control valve but i think i might be wrong.
Also if my 318is was made on 11/95 will it be a M42 or a M44. I thought it was a M44 as it was made on 11/95 therefore its a 96 BMW but then i found out that the M44 came with ODB II but i think my car has ODB I because i can check my fault codes using the pedal system. I need to order some parts but now im confused. Thanks Last edited by DarCwuN; 03-27-2003 at 12:55 PM.. |
What part of the engine did the part come from?
Is there a part # on the part? It looks like a vacuum regulator check valve, but it's hard to tell from that picture without more of a description.
1993 318i 1.8 liter, 4-cylinder MTX 120,000 mi. |
Here is another picture of the part inside the car, it is in a vertical position so its harder to spot but i have put a blue circle around it. Two hoses connect to the part one on the top the second on the bottom. There is also an electrical connector.
"part in car" Last edited by DarCwuN; 03-27-2003 at 01:58 PM.. |
Senior Advisor
That called a fuel tank vent valve, about $55.00. e-mail me
javier@pelicanparts.com I'll give you more info. or call 1888-280-7799 ex239.
...96 Chevy heavily Modded such items include... lil' pine tree air freshner.... duct tape rht front arm rest (i'ts falling) zip tie holding in rear tail light.... hi concentrate windsheild washer fluid... sticker of Speedy Gonzales..rear bumper... |
Javier you got mail. Any info on the M42 M44 issue.
