Hugo (guest)
Guest
Posts: n/a
Hello Pelican Staff.
I have a 1998 318i e36 M44 1.9 L. Which happens that the DME or ECU unit got wet. But I did not know until I tried to started but nothing happened. Then I disconnected the battery changed the fuel pump or main relay, and boom! some white smoke came out from the engine wire harness. It was a brown cable. Which is the middle one from the 5 points relay connector the one I replaced. So I replaced that wire with a new one and got a new relay. Try to started and worked but the engine was stalling like losing power. Then I checked and the ignition coil was melting. So I got a new ignition coil and it happened the same. So finally I check the DME ECU unit. And I found some corrosion around. I fixed the component that it wad fried and started and it was running good but once I drove it for like 30 miles the check engine light comes on. I tried to read it with the OBD II but no codes came out. Still running good. Then I drove it for like 60 miles more and when I stopped to get some gas the car did not started again. So I disconnected the battery and checked for the same relay but it was good and the wire that I replaced. I fill it with gas cause I thought it may needed some gas. Then I reconnected the battery and Boom! There was the same white smoke again. So I check the wire that I fixed. Fried again. I have bought another DME unit from a same model, year, make and engine side. 1998 318i e36 M44. Same numbers matching but I don't have reinstalled yet. Can you please help me out? Do I have to recode? Because is equipped with EWS II system. Or could you guys have any idea what it could be? I'll appreciate any ideas o diagnosis at all. Thanks!
This post was auto-generated based upon a question asked on our tech article page here: BMW E30/E36 DME Motronic ECU Swap | 3-Series (1983-1999) | Pelican Parts DIY Maitenance Article
Old 10-13-2017, 11:07 AM
Nick at Pelican Parts's Avatar
A brown wire is a ground. I would check the component it grounds and check if it is internally shorted from the water damage.
- Nick
