View Single Post
Tidybuoy Tidybuoy is online now
I've changed front struts several times.
The first time, I removed everything - But, I have since learned that you don't have to do that.
Just undo the top nut of the strut/shock (in the trunk). Then, you will have to compress the shock to get it to clear the fender. Just pull down with your hands until it is compressed enough to clear the fender. It's a little harder if you have gas pressurized shocks but can still be done by hand. Once compressed, you can tilt the strut housing so that the top is outside the fender and the strut can be removed.
There's probably a special tool to remove the top screw-on nut that holds the strut in place but I have always used a pipe wrench.
Replace the strut and re-install. I would recommend an alignment but check around to make sure the shop can co it. I initially took my car into Firestone and they told me that the rear wheels cannot be adjusted (which is flat out wrong). Also, if you plan on replacing other parts (like the tie-rods), do this before the alignment.
Old 09-12-2005, 12:40 PM
