Banned
throw out bearing 'mounting' when re-pairing engine/trans?
Mornin, germs-
Trying to turn the corner and start putting my motor back in (waaaay overdue), got the motor n trans paired finally - ensuring to catch the TOB ears w/ the release fork.
Question is... the TOB seems to have the ability to 'walk' toward the flywheel.
Is this normal? In that, it's loose there and then is pre-loaded w/ tension by the Omega spring once installed?
Want to be CERTAIN I get this right prior to install.
Regarding the infamous Omega spring... last time I dropped the motor I was able to 'unfurl' it no issue. This time - kerSPRANG... it shot onto the floor in pieces. I'm assuming I didn't break it and it's supposed to do that.
Any tips on re-installing 'that' while we're at it here?
Any insight to both of these quandaries is greatly appreciated - TIA!
Old 07-09-2018, 06:28 AM
There's a lot of play on the TB/Fork relationship, just make sure the ears are aligned to catch the fork. It always amazes me that it remains aligned each time i do this. You can look thru one of the holes in the trans to confirm. The Omega spring just need to be pried back in place. I can't remember exactly how I did it, as it's been several years since I've had my motor out. I've got some pictures that may help, send me an email and i'll send to you....timc1018 at hotmail...
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 07-09-2018, 06:40 AM
Banned
THANKS TIM! That makes me feel ALOT BETTER about the TOB! 8-)
YGM!
O-spring... I'd sworn I'd broke it when it let go, but the ends don't have any fresh break look to the metal... hoping thinking I'm OK 8-/
Old 07-09-2018, 07:24 AM
pic's sent.
Tim
1986 930
Old 07-09-2018, 07:42 AM
Brando
quattrorunner's Avatar
The fork doesn’t always line up correctly it’s awesome that it did for you. But even if it doesn’t it’s not that big of a problem to get it lined up correctly looking through the hole in the transmission. The next biggest problem that is seems you’ve licked is if the disc is not properly centered, if that’s the case then the transmission won’t properly butt up against the engine and that can be exhausting and time wasting. As far as the spring, that’s not a real big deal just make sure you take pictures off the Internet print them out because it can be confusing.
(Your welcome Ronnie)
Turbo powa!
1977 911s. it's cool
Old 07-09-2018, 10:04 AM
Ken911's Avatar
Every time I put that spring back in I litterally have to crawl under the car with a copy of the picture in hand to get it right.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 07-09-2018, 11:37 AM
Banned
lol - thanks Brando / Ken! too funny
yeah, I used Lord Jefferies' SC alignment tool wound w/ electrical tape and it seemed to work a treat - phew
a'ight... may send it north - tonight!
Old 07-09-2018, 12:22 PM
This post and picture from 2009 helped me get the Omega Spring back on.
Originally Posted by WERK I View Post
I remember! Amazing what a good nights' sleep will do for an ol' man.
If you look at Rod's (cl8ton) pic above, and look to the left. You see how the two levers(short and long) mount on the shaft. The long lever does not turn with the shaft but floats. To mount that omega spring, have only the long lever on that shaft. Swing the long lever out towards the bellhousing and then try to mount the spring at its two mounting points. The spring will go on very easy. Once the spring is mounted, push the long lever towards the position in the picture above. The tricky part is keeping the long lever from sliding down that shaft when you've mounted the spring. Two people make it a snap.
You'll be surprised how easy the springs sets in.
Derrick
Old 07-09-2018, 01:31 PM
mark houghton's Avatar
Fer true....
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 07-09-2018, 06:42 PM
Banned
thanks Derrick! Will give that a shot!
Old 07-10-2018, 05:25 AM
