Early Turbo Trunk Carpet Question
I own an early Turbo from 1977. The original trunk carpet has a burn hole in the carpet from the battery and I want to replace the carpet.
My car is very original and my question is: should I hunt and look to replace the carpet with a used carpet from another car or is there a replacement available in the market that looks just about identical to OEM? I hate to buy new only to get the carpet and it be miles from original in look and feel. Thanks in advance. Jamie |
I have the same burn mark, Jamie. I too, am unsure of what to do. Pelican has a Perlon kit for the trunk, but I can't tell how it is just from the pictures.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma Last edited by WPOZZZ; 12-09-2018 at 08:13 PM.. |
Hopefully someone shares their experience Bryan. Thanks for the bump.
I cut out an oval section from the original bad area (battery acid) and glued in good section from a vintage trunk carpet. It matched perfectly and you can't tell where the glued piece resides. Make sure you cut out the replacement section a little larger than the cutout hole so it will fit tight. The replacements trunk carpets that are available today don't have the same look as the originals.
Thanks Rich. Much appreciated
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Thank you guys for the scoop! Its helpful. I found a piece and will do the same!
Bryan, if you need a piece of the carpet, drop me a note as I should have some extra once done. |
