Early Turbo Trunk Carpet Question
I own an early Turbo from 1977. The original trunk carpet has a burn hole in the carpet from the battery and I want to replace the carpet.
My car is very original and my question is: should I hunt and look to replace the carpet with a used carpet from another car or is there a replacement available in the market that looks just about identical to OEM?
I hate to buy new only to get the carpet and it be miles from original in look and feel.
Thanks in advance.
Jamie
Old 12-08-2018, 08:56 PM
WPOZZZ's Avatar
I have the same burn mark, Jamie. I too, am unsure of what to do. Pelican has a Perlon kit for the trunk, but I can't tell how it is just from the pictures.
Old 12-09-2018, 03:17 PM
Hopefully someone shares their experience Bryan. Thanks for the bump.
Old 12-09-2018, 03:34 PM
I cut out an oval section from the original bad area (battery acid) and glued in good section from a vintage trunk carpet. It matched perfectly and you can't tell where the glued piece resides. Make sure you cut out the replacement section a little larger than the cutout hole so it will fit tight. The replacements trunk carpets that are available today don't have the same look as the originals.
Old 12-09-2018, 06:58 PM
Thanks Rich. Much appreciated
Old 12-09-2018, 07:04 PM
stevie 77 930's Avatar
i did the same except I brought it to my local dry cleansers/ seamstress and she stitched the repair with almost no visible sign
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 12-10-2018, 12:28 PM
Thank you guys for the scoop! Its helpful. I found a piece and will do the same!
Bryan, if you need a piece of the carpet, drop me a note as I should have some extra once done.
Old 12-10-2018, 12:29 PM
