BOV location
I've seen pics of Blow Off Valves attached directly to intercoolers. Mine is a plastic OEM version (i believe) in a 965 style intake elbow. I'll have my engine out over the winter doing an EFI conversion, is there any benefit to moving my BOV to my intercooler?
I think i'll be modifying my intake anyways after I eliminate the CIS system.
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Thanks Philip, any chance you can email me a picture of your BOV at some point as well as your air intake pipe?
Chain fence eating turbo
Correct, but putting the blow off valve near the outlet of the turbo, close as possible aids boost recovery
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
OK thanks for the info!
07 911 Turbo - Pilot Sport Cup 2 ZP 96 Carrera 4 - Toyo R888r 73 911E - Hoosier R7 + twin 75's 92 Corvette - Nitto NT01 14 BMW X3 - Pilot Sport A/S 4 |
Brando
That looks awesome but don’t you think the end tank on each side would be better if it had had a smoother transistion? Two 2” hoses running directly into the tubes and fins seem abrupt. I’m no engineer though.
Turbo powa! 1977 911s. it's cool |
Very good points. Thanks for posting that. Tanks are a little small also. No air ducting etc. If you saw the manifold, I think similar comments.
Not looking for horsepower however. 1850 pounds!
Mindtrust... I just picked up a powerhaus intercooler that has the boV directly to atmosphere. Can I just instal it or do I need to disconnect and re-plumb the OEM BOV ? Any harm having two in the system ?
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
one thing you want to check for if venting is if it is open at idle.
if so, it is an "air leak" and make it run lean at idle. if it is open when at cruise speed it will run rich. I don't think I would run 2. I have left the one in the elbow there but removed the vac/boost hose to it when I installed one on the IC and vented it
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
That’s exactly where mine is. It’s tucked nicely where the dizzy used to be.
Anyone not running a blow-off or bypass valve?
86 911 Turbo - K27-7006, BB 3" Dual outlet, BB IC 96 911 C2 6sp dd 88 M3 |
Turbonut
Very bad for a turbo.
Other option would be to use second throttle pre-turbo like they did in 80's turbo era.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
I worked for 1G Racing in Ross, Ohio, US distributor of Noble cars about ten years ago. Noble cars were powered by a twin turbo Ford V6 and one of the distinguishing feature was that it did not have a bypass or blowoff valve.
I was aware of this before I went to work for 1G because I had read an article about the Noble. Around that time I had been working to build a turbo converted VW Corrado engine for my 92 GTi and one of the books I had studied was Corky Bell’s book Maximum Boost. People I talked to about eliminating bypass/blowoff said similar things like Raceboy above. One day I called Corky Bell and questioned him about this subject and what he told me is that there’s a lot of misinformation about this subject and that not having a valve is not detrimental to a turbo system. The primary reason factory cars use them is to eliminate the “chirping” noise that emanates from the turbo when you get out of the throttle, while shifting for example. The benefit being you don’t loose the boost in the system while you shift, and for a while Noble was faster to 60mph than any exotic on the market. Although, I did end up using a blowoff valve on my GTi, it was primarily for the cool noise it made as you shifted, purely cosmetic, if you will. Some of the Noble customers did install blowoff valves for the same reason. I can also confirm that the Nobles do make a “chirping” noise Corky had mentioned but I did not think it was that bothersome.
Ingenieur
Nope. We do it because it is slower without it in normal driving.
When you close the throttle, the pressure at the compressor outlet causes the turbo to slow its rotation. When you open the throttle back up, it has to spin back up again. With a compressor bypass, the turbo speed stays up, or even increases slightly. Higher speed = More boost. In a sport like drag racing you can do things differently. You can shift with the throttle open, and let the rev limiter take care of the engine revs. In this case, the compressor bypass doesn’t make much difference. Last edited by Speedy Squirrel; 12-01-2018 at 03:18 PM.. |
