Rear tire size alternative ...
Any other size then 245-45-16 is good for the rear on 89 930 on stock wheels
Unfortunately there isn't anything wider in a street tire available.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
255 50 16 BFG G Force Sport Comp 2 on 16x9 rears fuchs, with a 1” spacer.
245 seems very narrow for a turbo, I'm running 245's on my SC.
245 was the stock size. The 255/50/16 mentioned above is 1.5” taller (26.1” vs 24.6”) and about .750” wider than the 245/45/16. A good size would be 275/40/16, wishful thinking.
What about the Michelin TB tires?
Rahl |
Only available in 15’s.
Is there a Fuchs wheel with the correct offset for a 275/40/16 tire......that would be a perfect wide load for the rear of 930....no spacer needed!!
Unfortunately there is no 275/40/16.
Capt Bob
I'm running 17's -
255/40/17 on the rear |
