930 tach false reading with MSD
Hello all,
I've got a problem with the tach of my 87 930 using MSD 6AL CDI.
It reads quite consistently a wrong low value for the RPM.
For instance at around 6000 RPM, it reads 5000. Idle reads 600 for 900.
I've read many topics about MSD 8920 tach adapter and none of them really describes the same problem I'm facing. Some had erratic readings some not working but none had wrong readings.
Does any of you faced the same issue?
Would you think that the MSD 8920 can be the cure to my problem?
Arnaud
Many projects on the way...
1987 930 Road trip car (1/2 owned)
1982 DP935 future beast
1969 911T rust bucket
1966 911 Buffum college car (1/2 owned)
Old 04-25-2019, 06:55 AM
Do you own an oscilloscope or can you build one with a Pi https://bitscope.com/pi/? or https://www.raspberrypi.org/blog/build-oscilloscope-raspberry-pi-arduino/
It would go a long way to figuring out the problem.
See also:
* Tachometer Compatibility Chart
* HELP! tach died and I need to know what can replace it!
Alternately you could simply start rebuilding or swapping parts at random and see if the problem goes away. Start with the a tach rebuild.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 04-25-2019, 01:43 PM
Thanks, I'll get my oscilloscope back soon and do some more measurements.
I've checked again my MSD, it is properly set with one cylinder selection loop cut and the rev limiter set to 6500.
Checking the documentation, I found a nice feature of the digital 6AL, is the Rev limiter verification.
At each "key-on", it will generate a frequency to display the set rev limit on the tach.
Here below is the video I took of this feature on my car:
https://www.youtube.com/watch?v=CRMfknLT3eU
Seems that the needle sweep to 6500 then stabilize at 5100.
I guess then that there's something wrong inside the tach as my innovate data logger reads properly the RPMs.
Time to open the tach for visual inspection for any burnt component.
Old 04-28-2019, 03:57 AM
Quick update, looks like the culprit is the tach, here’s a video taken with another one:
https://youtu.be/3Nu4gE6aLI8
Time to open up the original one...
Old 05-06-2019, 06:58 AM
Diagnostic update:
I should have open my eyes before:
It was written quite obviously 8cyl on it as confirmed by the inside...
How in the hell a modified 930 tach (with te right date) ended up in my car...
Hope the little adjustable resistor is the key to adjust the RPM display.
Old 05-07-2019, 09:52 AM
Can you configure your oscope to output a wave pattern?
If not, a 555 circuit or something similar switching 12v through a transistor to generate a 12v square wave. Pretty sure its once per ignition event, or 3 times per rev, so a frequency of 150 Hz should show 3,000 rpm.
Old 05-07-2019, 11:19 AM
Hello all !
I finally made some progress on this issue
Here’s the little test rig I set to calibrate the tach and the final result:
I used a 3€ square wave generator, a salvaged 12v power supply and a USB oscilloscope I bought many years ago...
Funny to observe that the response of the tach is not perfectly linear, when 1000 and 6000rpm are aligned, 2, 3, 4 and 5000rpm aren’t....
Old 11-13-2019, 03:15 PM
ELZ's930's Avatar
That's interesting. My tach in my 84 930 reads consistently low. Same MSD key on feature sends it to about the same low reading as yours. Maybe I have an 8 cylinder tach too.....but I doubt it.
the911den.com
Instagram / UberPorsche930
https://www.youtube.com/channel/UCg4ZbACRJsODXgnlMVZsjEg?view_as=subscriber
Old 11-14-2019, 10:05 AM
The setting is made by the little adjustable resistor we can see on some of my previous pics.
You have 2 options to do the setting:
- use the key on feature of you MSD
- invest in a 3$ square wave generator, the one I have is accurate, the oscilloscope isn’t needed.
To make things easy, I made a quick research on Amazon US, here’s a link to the same unit I bought:
https://www.amazon.com/uqiangbao-Adjustable-Rectangular-Electronics-Accessories/dp/B07PHB9VNY/ref=mp_s_a_1_9?keywords=square+wave+generator+pwm&qid=1573766458&sr=8-9
Shipping from China wasn’t very fast but it arrived anyway...
Old 11-14-2019, 01:15 PM
ELZ's930's Avatar
I'm down for adjusting the tach myself. So...just turn it until the correct value is reached in terms of the MSD, seems logical. I did have the face changed to 10K?
and thank you very much for the link! How nice!!
Leonard
the911den.com
Old 11-14-2019, 01:27 PM
