cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
need whole turbo setup
Hey Folks,
I had a line on a local guy that was removing his entire turbo setup and going back to stock. Ended up selling the car instead. I am back to the drawing board for parts. Looking for J pipe and any other components to convert my 3.2, with Turbo Tail, into a Turbo. Complete set up would be ideal.
This has to be the best place to look and get lucky.
Thanks,
Chris
89, 3.2, G50 Carrera
Old 05-20-2019, 10:54 AM
Turbonut
Raceboy's Avatar
Start with plug and play standalone ECU so you can actually control the turbo setup, for example VEMS that plugs into factory DME connector and has integrated wideband lambda controller. www.facebook.com/vemsporsche
I would not buy eny factory parts as they are not optimal at all. I would make custom twin scroll J-pipe and downpipe, buy biggest intercooler I can fit from ebay, modify end tanks, buy 600+ cc injectors and start looking at stronger clutch
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 05-21-2019, 05:49 AM
scottrx7tt's Avatar
Factory j pipe is the easiest way to turbo your car. I made 402 hp on my factory j pipe.
Old 05-21-2019, 08:15 AM
T77911S's Avatar
i may be selling my 7006 turbo if you need one. has about 15k on it since rebuild by durabuilt
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-21-2019, 08:22 AM
Turbonut
Raceboy's Avatar
Factory j-pipe just merges two exhaust flows together, nowadays it would be pointless not to go divided turbine. Plus it is easy to make your own j-pipe.
Old 05-21-2019, 09:02 AM
cmcfaul's Avatar
the j pipe just replaces stock cat with a place for the turbo and wastegate to go.
cm
Old 05-22-2019, 08:16 AM
onboost's Avatar
If I were to do this I'd pick-up a set of used turbo headers w/or without heat, puts you ahead of the came since you're modding anyway.
Couple of different flavors to go with turbo & wastegates, keeping in mind that you will build/set for low boost application given the 3.2 CR. Unless you're planning to swap pistons for a lower CR than standard Carrera.
Your biggest decision in my opinion will be what intercooler set-up and electronics you want to run.
This may might solve your IC decision.. (no affiliation)
http://forums.pelicanparts.com/porsche-911-technical-forum/1030425-fs-full-bay-intercooler-carrera-intake.html
RGruppe #180
Old 05-24-2019, 06:41 AM
scottrx7tt's Avatar
I have my old intercooler setup for sale. Just posted it. Bought from Tippy a few years ago. having trouble getting pics to load. Its a decent unit.
Old 05-24-2019, 07:04 AM
cmcfaul's Avatar
I am hesitant to replace the headers as I need to keep it simple at this point. The exhaust bolts are all original and will probably break some when removing. I need heat. J pipe, chip, ebay IC is what I am thinking now. I can improve over time. Engine will have to come apart sometime. Can lower compression, upgrade rod bolts, etc then. One step at a time.
For now KISS it. Get the turbo installed, learn, tune and improve is the path I am thinking.
Chris
Old 05-24-2019, 07:05 AM
Stranger on the Internet
patkeefe's Avatar
Lots of luck
Patrick E. Keefe
78 SC
Old 05-24-2019, 07:16 AM
cmcfaul's Avatar
Just need the parts
Old 05-24-2019, 07:20 AM
onboost's Avatar
Chris
Ok, I get all that.. if KISS is the objective, then you've found your IC.. the one posted. I would go with that given the simplicity, and price over God knows what on ebay. Just saying.
Jay pipe should work for you.. try DC Auto in NC or WeekendRides in Scranton they may have one, or of course TurboKraft in AZ. Once together, instead of a generic chip, see John Behe and let him tune/burn you a chip set to you configuration.
Good luck, have fun!
RGruppe #180
Old 05-24-2019, 07:45 AM
cmcfaul's Avatar
Step one - Got the J -pipe
need Turbo / Wastegate and muffler next
May see if it runs at that point
Then add IC, chip and injectors
Chris
89 G50 carrera
Old 05-30-2019, 01:16 PM
