Turbofrog
Heh, you already saw it here: Show us your light weight 930s!
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
Yeah, but I have severe short term memory issues. What size is the core? I'm thinking of downsizing my intercooler but I'd like to still have it flow back to front rather than left to right for more CFM capacity.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Turbofrog
Its about 29*9*2inches. I have done some air blocking and flow directioning mods for it so the fan pulls air through it and @ over 45 Celcius WMI kicks in which it rarely does.
My MAT Atmo delta is about 20-25 C on WOT pulls.
Turbofrog
Since my last post I went for my smallest turbo K7200R and while it was faster on spool it really died after 5000rpm so last weekend I installed my Holset HX40super back and now its with the 4 port mac valve and I even bought two 10psi springs for the ultragates to test later. Weather has become wet but what I gathered from first test drives the boost is managable with 7psi springs but I think I will gain spool with stiffer springs. So far I've only tested 0.9bar boost with the hxsuper and my clutch have healed a bit as it even hold the 1.5bar spike on second gear with the k7200r.
Paypal unfortunately took the sellers side (idiots) so I now have a wrong 594 PP and 2 extra OE release bearings, DUH
Turbofrog
Here is my current situation after figurin out why I get massive taper on boost even with my holset hx40 super. First I changed my 3.5in intake silicon humphose for the stock smashed metal pipe thinking it had collapsed just like I had my soft Metering Head rubber elbow collapse when I was still CIS.
Nope, did not help a bit which was very disappointing. Then I figured it MUST be the silencer flap I have on my zork so I installed several extra springs for it so it would not move with a lot of exhaust getting past it. Heureka, no more taper, so now I need to find one rigid spring so it doesn't look so stupid as it does now. 1 bar @3000rpm in 4th gear. 1 bar @3400 in 3rd gear 1 bar @4050 in 2nd gear 1 bar @6000 in first gear ![]()
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg Last edited by smurfbus; 09-13-2020 at 05:25 AM.. |
Turbofrog
I downloaded my sd card logs which are 10 samples per second and I think I still have the silenser flapper blocking flow in 1st gear high rpms, see pic. MAPxRPM is close to MAF values which is airflow. If I cant find a short and strong spring I will remove the flapper to be sure I don't have exhaust backpressure.
Gotta give credit to megalogviewerHD even though it has its shortcomings. Logworks had very nice run comparison tool 10 yrs ago but MLV still lacks it. ![]()
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg Last edited by smurfbus; 09-13-2020 at 12:06 PM.. |
Nice data
![]() How do you measure back-pressure? Have you done a leak test? (just for the sake of it) Sometimes I have noticed the airfilter in fact was way too small when looking/asuming fine. So I found high vacuum on filter side. 1st gear have short time to build up boost so if critical vacuum is present on filter side, it might be visible in 1st gear more than rest of gears. Just a thought |
Turbofrog
Boost was better today when I removed the flapper, but bp still high on 1st and 2nd on high rpms. My bung is just before turbo flange. Found another problem. Fpr falls. Checked my 5micron filter and it was clean. Added second 044 in place of front 100micron filter. Then found one tb vacuum hose complitely off the one at the back. That alone might have big delta for fpr hose on the other side of tb. I did leak test a month ago with no leaks so this was new leak. also need to add a breather for fuel tank as there was vacuum last time I opened the cap. Do we have option for wented gas cap?
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg Last edited by smurfbus; 09-14-2020 at 01:01 PM.. |
