930 Clacking noise
Was driving my 89 930 Friday night. Out of the blue it started having a clacking sound. No smoke, good oil pressure, not low on oil, it starts on one kick. Towed it back home did not want to take any chances. Car was running perfect prior the occurrence.
Sounds like the noise is coming from the passenger side of the motor on the top First video day after https://youtu.be/LzOaDtC7TnI Last edited by ljpviper; 03-02-2020 at 03:45 AM.. |
930 noise
how many miles on the engine
sounds like a rocker. pull the valve covers and check for lose rocker or even a rocker shaft that has come lose. I don't know if or what a broken valve spring would sound like but that is another possibility
82 k miles on it.
Non User
Exhaust leak? Do you have the air injection plugged? One fallen out?
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
Sounds more like valve noise, than exhaust leak. I will check this evening.
well? i would say broken valve spring.....remove the cover and inspect each cylinder just like you would do the valve adjustment..so they rock then you can use your hand and if you are able to push on the rocker arm that is the culprit..it is an easy fix with the correct tool
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks Ivan, plan on inspecting it this weekend.
Is it something I can tackle myself. Unfortunately the Porsche mechanic I know moved to Colorado. I dont like taking the car to shops that I am not familiar with. I do all the basic maintenance on my car. Never delt with valve adjustment I had a 930 back in the 90s I remember watching my buddy adjusting the valves, was not too bad. Thanks |
Locate the bad one.. i think you can do it your self.
You need a compressor to put air into that cylinder and the tool to compress the springs in order to remove the 2 keys which hold the washers on top of the spring..the tool is this one... one is for the intake and another for exhaust side.. maybe even our host has them in stock ....
I have a nice size compressor. Let me see about locating the tool.
broken spring may be hard to spot (esp if inner). If not visibly broken you can check them by getting the engine to the usual valve lash spot, then leaning on the rocker with a lever type tool - something you can make up. Can prob take a pic of something I made some time ago. The valve with a broken spring will be quite soft compared to the others - obvious.
Can do in place. To get compressed air in cylinder you need to fab a tool which the compressor can hook on to and had spark plug fitting at other end. Can do a pic in a few days if nothing else shows up. Need to get about 100 psi in there. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
the tool Alan mentioned is simple compression check tool where you would remove the gauge .One end goes to the air and the other to the cylinder after you remove the spark plug .Also you have to remove the valve inside the tool-which is there to hold the air inside the cylinders when you do ,the compression check.
If you are in Europe i can lend you the tools ....since i do not know where u r ... Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 03-04-2020 at 01:52 AM.. |
Ivan,
I am in the US, Miami actually. I might leave this one to the mechanic. Thanks for all the help. I will post what went went wrong as soon as I know. Thanks, Larry |
Turned out to be a loose rocker, what a relief.
Easy fix - depending which one and which way around the locating bolt is fitted.
Good luck. Alan
