tops911's Avatar
spark plug questions
I have a question for the group. I typically run Bosch plugs, I tried NKG and the plug wires ended up falling off. The wires never "snap' on like they do with the Bosch plugs and vibrate loose. My wires are factory. Has anyone ever experienced this before?
Thanks, Frank
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 07-11-2020, 02:49 PM
I've never had an issue with plug wires not locking on Bosch plugs.
I have never switched from the recommended plug either.
Derrick
Old 07-13-2020, 11:24 AM
Have you tried unscrewing the little silver tip from the Bosch plug and screwing it on the the NGK plugs?
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 07-13-2020, 12:43 PM
tops911's Avatar
The NKGs had solid ends that did not screw off.
Old 07-13-2020, 05:13 PM
OK, off of the top of my head, you could pull the boot off of the connector and look inside to see if you can bend the two copper tabs or the spring clip in there to decrease the diameter to the size of the NKG plug end. I have not looked in there for ages but worth a look.
Rahl
Old 07-13-2020, 10:01 PM
