Wastegate vent routing thru tin - why?
Looking at the driver's side tin on the 930 engine, it appears there are two round holes, one for the control line to the wastegate and one for the vent line off the wastegate.
1. Was the Wastegate vent line routed thru the tin (instead of just being open air) for emissions? 2. What did/does the Wastegate vent line route to?
1987 M491 Widebody, Nautic Blue / Linen with a 1979 930 3.3L Cali Engine |
Crotchety Old Bastard
Atmospheric pressure must be on one side of the diaphragm as a reference, boost is on the other side. Diaphragm moves so vent is dynamic.
Vet line is in engine bay to protect from road debris and water blocking it.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Does that mean that the vent line from the wastegate is supposed to be open in the engine compartment, not hooked up to anything?
Correct. Not hooked to anything
Brandon ‘91 Turbo |
Yes. At least on mine, and pretty sure unmolested until I started touching it inappropriately, there was a short roughly 75 degree bent aluminium tube stuffed in the end of the hose so open end of the vent tube points downwards.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
The cleaner the air is at the vent side of the wastegate the better. 924 turbos use the same wastegate but have a short little vent cap, those are located in the "dirty" airstream under the car. A few high Mileage ones I have taken to bits are full of fine grit from the road, this can be very abrasive and cause wear on the inside of the housing and diaphragm. So having the vent up higher in the cooler cleaner side of the engine should increase the lifespan.
David Performance Enginerding |
Metal Guru
The wastegate vent is exposed to a lesser amount of dust by being in the engine compartment than it would if it was open to the road, but it still gets dusty in there.
The next step in ocd cleanliness is to attach a length of corrugate plastic tubing to the hard vent line, the longer the better. It will force any dust to drop out of the airflow before it can enter the wastegate.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
That's a good idea.
Capt Bob
TiAL waste gate
On my 930 the waste gate vent is up in the engine compartment.
Thread Tools | |
Rate This Thread | |
