Twin Turbo leak after shut down
Sorry my bad English. I’m from Norway.
I have a 3.4 Twin turbo engine in my 81 930.
The oil return from the turbos goes into the same drip tank. This tank is maybe 0,3-0.5 Litres and has a breather on top(5cm long, thin pipe(1cm?). This tank have a line to a 12v scavenge pump.
The issue Is that after shut down the oil is over the following hours leaking throu the breather on the top of the drip tank. Over the night maybe 0,5 litres leaks on the ground. Belive this is from the Turbos by gravity.
The pump shuts down when the ignition is switched off.
What to do? Bigger tank, higher/longer pipe from the breather, delay timer on pump?
Old 09-23-2020, 03:42 AM
Turbofrog
smurfbus's Avatar
Do you have the ball in the banjobolt near thermostat? You could add a spring in there to help keeping the oil seepage if it comes from there.
Also check your oil level. It helps to keed it near the low limit.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 09-23-2020, 04:14 AM
Bigger tank and delay timer
Tony
Old 09-23-2020, 04:26 AM
Turbofrog
smurfbus's Avatar
I dont think a timer is any good in this scenario as its a mechanical scavenge pump
Old 09-23-2020, 06:19 AM
OP says 12v scavenge pump, but I agree this is treating the symptom not the root cause
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 09-23-2020, 06:34 AM
Crotchety Old Bastard
RarlyL8's Avatar
Where does the electric scavenge pump empty? Oil is back flowing when the pump is not in operation. If oil is backing up via gravity feed then a check valve is needed.
Old 09-23-2020, 06:38 AM
TurboKraft's Avatar
Photos of how you have this plumbed would be helpful.
The 9mm ball bearing in the factory oil supply is critical, and our spring pressure check valve is better.
Often, a check valve on the outlet of the electric pump is helpful, too, even if you have the pump run on a few seconds after shutdown (ex: delay relay or ECU-triggered).
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 09-23-2020, 11:35 AM
